Squeaking noise in back left wheel while in reverse gear - Yanmar 3000
wricwo
Postby wricwo » Sun Apr 29, 2018 7:42 pm
I’m hearing a squeaking noise when the tractor is moving in reverse that sounds like it is in the location of the left rear wheel. Not sure exactly what’s causing it. Left side brake?
Re: Squeaking noise in back left wheel while in reverse gear - Yanmar 3000
Postby winston » Mon Apr 30, 2018 5:44 am
Figure out a way to use a stethoscope or long screwdriver to listen while moving. You should be able to narrow down the source. https://www.harborfreight.com/mechanics ... 63296.html
Postby Norm » Mon Apr 30, 2018 9:05 am
Tighten your lug bolts.
wricwo
Postby wricwo » Sun May 06, 2018 5:19 pm
I found it. Thanks again guys.
Desert Dave
Postby Desert Dave » Mon May 07, 2018 12:59 am
wricwo wrote:I found it. Thanks again guys.
Great, mind telling us what you found?
PaulW
Postby PaulW » Mon May 07, 2018 5:49 am
Does the 3000 have the bolt in the centre holding the hub to the axle? One of mine was loose making a squeaking sound too.
Paul W YM1500 & YM14 MkII
