yanmar 1300 D
browland
yanmar 1300 D
Postby browland » Sun Apr 15, 2018 3:54 pm
Why won't it start with front loader disconnected
Re: yanmar 1300 D
Postby winston » Mon Apr 16, 2018 5:45 am
If you have disconnected hydraulic hoses and dead heading your pump that could be the reason. Hard to tell from where I am sitting. :mrgreen:
Is it slow to spin over?
Re: yanmar 1300 D
Postby Norm » Mon Apr 16, 2018 6:11 am
What do you mean by "why won't it start" "disconnected"? More info needed.
browland
Re: yanmar 1300 D
Postby browland » Tue Apr 17, 2018 9:29 am
Re: yanmar 1300 D
Postby winston » Tue Apr 17, 2018 9:33 am
See post #2
browland
Re: yanmar 1300 D
Postby browland » Tue Apr 17, 2018 11:37 am
It spins over just fine. Since it dead heads the pump is there any thing I can do to make it run with out hydraulic lines disconnected ?
browland
Re: yanmar 1300 D
Postby browland » Tue Apr 17, 2018 11:38 am
It spins over just fine. Since it dead heads the pump is there any thing I can do to make it run with out hydraulic lines connected ?
browland
Re: yanmar 1300 D
Postby browland » Tue Apr 17, 2018 11:47 am
Disreguard the post where I said disconnected.
Re: yanmar 1300 D
Postby Aaron » Tue Apr 17, 2018 11:47 am
You are not giving us much to work with here.
O~o\
Re: yanmar 1300 D
Postby O~o\ » Tue Apr 17, 2018 4:59 pm
" front loader disconnected, disconnected hydraulic hoses, with out hydraulic lines disconnected ?, Disreguard the post where I said disconnected" :roll:
This must be a comedian plying his skills here. Not to be disrespectful, but this made me laugh!
Next: After disconnecting the hoses, they remain connected!
browland
Re: yanmar 1300 D
Postby browland » Tue Apr 17, 2018 5:13 pm
Sorry first time doing this got my words mixed up
Re: yanmar 1300 D
Postby winston » Tue Apr 17, 2018 5:28 pm
Your tractor has an open center hydraulic system which simply indicates the pump is circulating the fluid anytime the engine is running. "If" and this is a big "IF" you have removed both the inlet line to your loader and also the outlet line from your loader then you are likely dead heading the pump.
"IF" that is the case then simply connect the disconnected hoses from the loader to each other and your circuit will be complete.
Having said all that I am not sure that is your situation. Maybe more pictures showing what is unhooked, etc.
Re: yanmar 1300 D
Postby Norm » Tue Apr 17, 2018 6:02 pm
"IF" the engine still spins over as normal that is probably not related to your problem.
browland
Re: yanmar 1300 D
Postby browland » Wed Apr 18, 2018 10:24 am
Thank you Winston that is the problem . Thank you again.
