Remove PTO overrun clutch
MRMNTS
Postby MRMNTS » Mon Apr 09, 2018 5:44 pm
Hi,
My 2210D came with a overrun clutch attached to the PTO. The grease zerkes are gone and I'm trying to figure out how to remove this thing. When I look in the holes, I see solid steel. Nothing I can punch out. How can I remove it?
Thanks for any suggestions.
Re: Remove PTO overrun clutch
Postby Norm » Mon Apr 09, 2018 9:08 pm
https://www.youtube.com/watch?v=O1et1rIU2CU
Those pins tend to break and clutch moves in or out. you will probably have to force the clutch off the shaft or move it until you can see the pin in the hole. QD clutch is much better.
MRMNTS
Postby MRMNTS » Tue Apr 10, 2018 5:59 am
Thanks Alan.
I assume it is not a good idea to anchor the clutch to a tree and let the tractor pull itself away from the clutch.
I'll spend some time on it this weekend.
Postby Norm » Tue Apr 10, 2018 8:36 am
If the pin is, in fact, sheared rust is the only thing holding the clutch on the shaft. Penetrating oil and hammer should work
Postby Aaron » Tue Apr 10, 2018 9:57 am
I have had to cut the outer portion off with a grinder wheel before. Then grind down & hammer out the mangled roll pin and pull the rest off with a prybar and hammer.
Pulling on a tree would not get you nearly as much force as you would get with a prybar and you would 4,000% more likely to damage something.
MRMNTS
Postby MRMNTS » Tue Apr 10, 2018 4:24 pm
I shifted PTO into gear and started turning the ORC until I found the hole for the pin. I then pounded the sucker out and the ORC slid off.
All I needed was a little research and a little confidence.
Thanks everybody! I will be ordering a new QD ORC shortly :D
Users browsing this forum: No registered users and 10 guests
