Throttle
dljcorbett
Throttle
Postby dljcorbett » Wed Mar 07, 2018 2:11 pm
Hi There,
I know little about mechanics but am trying to figure out an issue with my yanmar tractor. The throttle acts like it is stuck open, the tractor fires up as normal but is in full speed however the throttle isn't stuck. Someone stated there could be a piece in the fuel pump stuck open. Problem is I live in the middle of no where, finding someone to come out is difficult but I have a neighbor than can help if I am able to figure out the problem a bit better - anyone know what to check or have any ideas? Thanks
Re: Throttle
Postby Aaron » Wed Mar 07, 2018 2:33 pm
What model tractor do you have?
Re: Throttle
Postby alan » Wed Mar 07, 2018 2:59 pm
Unlikely but just in case -- are you referring to the foot throttle (which self-releases), not knowing about the hand throttle (which stays where it was last left)?
Re: Throttle
Postby winston » Wed Mar 07, 2018 5:54 pm
Sounds like your injector pump rack might be stuck. Model number might help.
dljcorbett
Re: Throttle
Postby dljcorbett » Wed Mar 07, 2018 9:02 pm
The tractor is a yanmar 240D if that makes sense.
The hand throttle moves just fine and even when placed on the lowest position, the tractor acts like it is in the highest position (full throttle). The inspection plate om the throttle was opened and found to be moving back and forth but the tractor is not responding.
Re: Throttle
Postby winston » Thu Mar 08, 2018 5:37 am
Not sure what you are calling the "inspection plate" on the throttle. #21 on this parts drawing is the injection pump rack. The little pin on it attaches to the governor linkage. Is this what you checked for free movement? https://www.hoyetractor.com/CTGY/YM2000INJPUMP.htm
#30 here is the plate for inspection. https://www.hoyetractor.com/CTGY/YM2000BLOCK.htm
Re: Throttle
Postby alan » Fri Mar 09, 2018 12:15 pm
Likely a stuck rack.
Re: Throttle
Postby Norm » Sat Mar 10, 2018 8:01 am
If it has a foot throttle and it is not restoring to the "up" position, (broken spring or bind), it will do as you mention. Follow the chain of parts and you will find the problem.
Users browsing this forum: No registered users and 14 guests
