Yanmar 1300D
warburtonplayer
Yanmar 1300D
Postby warburtonplayer » Sun Feb 25, 2018 6:06 pm
Here is a nice 1300D that I just finished today, I like refurbishing these littler tractors they are a lot of fun and easy to work on. Let me know what you think.
**** Edited by Aaron to remove the link to selling tractor. Please see link below *****
viewtopic.php?f=11&t=5581
RokonDon
Re: Yanmar 1300D
Postby RokonDon » Sun Feb 25, 2018 6:41 pm
That looks nice!!! Very well done.
Re: Yanmar 1300D
Postby alan » Sun Feb 25, 2018 8:50 pm
I think it's a fine ad for a fine-looking tractor -- hope it works out for you.
(I don't know the meaning of "player" in your name but as a kid I took lessons from musician Robert Warburton.)
Re: Yanmar 1300D
Postby winston » Mon Feb 26, 2018 4:52 am
Nice looking tractor. Wondering why you have the left front tire mounted backwards? :o
warburtonplayer
Re: Yanmar 1300D
Postby warburtonplayer » Mon Feb 26, 2018 4:56 am
Thats a great question???? I must have mounted it backwards.
PatrickHanna
Re: Yanmar 1300D
Postby PatrickHanna » Mon Feb 26, 2018 7:13 am
winston wrote:Nice looking tractor. Wondering why you have the left front tire mounted backwards? :o
Do you mean the right front tire?
Re: Yanmar 1300D
Postby Norm » Mon Feb 26, 2018 7:55 am
Tires need to be turned around on wheels, then wheels installed in standard config. You should never turn front wheels out for wider stance. It serves no purpose and puts undue strain on front axles.
PatrickHanna
Re: Yanmar 1300D
Postby PatrickHanna » Mon Feb 26, 2018 8:12 am
Looking at this picture it looks like switching the front wheels and attaching both of them in the correct narrow stance will fix it.
Re: Yanmar 1300D
Postby winston » Mon Feb 26, 2018 4:14 pm
PatrickHanna wrote:Looking at this picture it looks like switching the front wheels and attaching both of them in the correct narrow stance will fix it.
I agree with Patrick.
I did say left was backwards, left in picture, not from drivers seat, should have been plainer. :oops:
Re: Yanmar 1300D
Postby Norm » Mon Feb 26, 2018 6:19 pm
Yep, you are right, Patrick. Good eye.
warburtonplayer
Re: Yanmar 1300D
Postby warburtonplayer » Mon Feb 26, 2018 11:56 pm
This is a prime example of why happens when I rush to get a project done! Problem has been corrected.
Muzmic
Re: Yanmar 1300D
Postby Muzmic » Wed Feb 28, 2018 8:02 am
If a wider front wheel stance is unnecessary, or can damage axles, how does the addition of a fel affect components? I've seen quite a few of them.
O~o\
Re: Yanmar 1300D
Postby O~o\ » Wed Feb 28, 2018 9:07 am
Muzmic wrote:If a wider front wheel stance is unnecessary, or can damage axles, how does the addition of a fel affect components? I've seen quite a few of them.
I have a V2 loader on my 2210D. After breaking my driveshaft to the front axle, I have these observations:
*I now run my front tires at their maximum recommended pressure to minimize traction up front and lessen wear on components.
*I only use 4x4 when absolutely needed, especially when loader is in use.
*From what I have learned here and elsewhere, none of these old Yamnars were built for front loader stresses. They are an awesome add-on, but use caution or you may damage the drivetrain or even split your tractor with too heavy a load and agressive use.
*Consider the addition of a sub-frame. When time allows, I plan on adding one.
*Last, always run front rims in their narrow stance and never put ballast in front tires.
BTW - Warburton - nice refurb!
warburtonplayer
Re: Yanmar 1300D
Postby warburtonplayer » Wed Feb 28, 2018 2:18 pm
Thanks this is the fourth yanmar I have done they always turn out really nice. I have a small tractor shop at my house.
Re: Yanmar 1300D
Postby alan » Thu Mar 01, 2018 6:04 am
"... how does the addition of a fel affect components?"
In the first year of use, a knuckle arm on my 226D snapped. Three times. (Fixed under warranty, and the last one had a heavier design and has lasted fine.)
Fast forward to a decade back. Had recently had the lift cylinders repacked. Was pulling up something stuck in the ground, full RPMs, max upforce.
Unless you'd like lots of noise, smoke, inconvenience and cost, you do not want to experience the bell housing (which Yanmar uses as a frame component) fracturing.
I'd suggest install a subframe or go easy raising the loader (or pulling up with a hitch-mounted hoe).
