Yanmar 1500 Clutch
warburtonplayer
Yanmar 1500 Clutch
Postby warburtonplayer » Wed Feb 21, 2018 5:03 am
I just got a Yanmar 1500, when trying to shift gears it has a lot of grinding noise and the clutch seems really low. Should I try and adjust the clutch before splitting the tractor to change the clutch. The tractor has 627 hours on it and it is in great shape. Also is there a manual on how to adjust the clutch. Thanks
Re: Yanmar 1500 Clutch
Postby Aaron » Wed Feb 21, 2018 9:38 am
If there is a grinding noise when you press the pedal then something is seriously wrong and is only going to get worse. Adjusting will not likely help. You can see the adjustment procedure at the end of this video ->
https://www.hoyetractor.com/ClutchVideo.htm
Postby winston » Wed Feb 21, 2018 11:26 am
I think the grinding noise could be coming from the gears if the clutch is not adjusted properly. Should have 5/8" free play at top of pedal.
warburtonplayer
Postby warburtonplayer » Wed Feb 21, 2018 12:33 pm
I tried tighten the rod and it does not change anything. If the tractor is in gear and the clutch is pushed in it will still move forward. I think the best solution is to go ahead and order the clutch kit.
Postby Aaron » Thu Feb 22, 2018 9:05 am
I misread your first post. I thought you said it grinds just from pushing in the clutch pedal. I think your clutch is probably stuck. Link below
https://www.hoyetractor.com/clutchstuck.htm
warburtonplayer
Postby warburtonplayer » Thu Feb 22, 2018 12:24 pm
Ok so tried hooking my tiller up and running it up and down with the clutch pushed down and then would pop it. It is apparently stuck good, I ran it for about 10 min and still did not break loose. Any other suggestions?
