Sleeve clearance
Hnewman144
Sleeve clearance
Postby Hnewman144 » Sat Feb 17, 2018 12:49 pm
Is there supposed to be a certain clearance for the sleeves where they meet the top of the block, or bottom of the head? I installed new sleeves in my ym1500 and one of the seems to stick up a hair more than the other. You can't see it but you can feel it. I tapped on it some more with a clean wood block and a hammer but it will not go down anymore. Not sure if this will cause a problem or not.
Re: Sleeve clearance
Postby winston » Sat Feb 17, 2018 4:27 pm
I can tell you a 155 is suppose to have .0019 to .0051". I can only guess your 1500 should be about the same.
The 195 (1700) is to have .0028 to .0059".
Your 1500 is in between these two in size.
Hnewman144
Postby Hnewman144 » Sun Feb 18, 2018 12:56 pm
Why are they not cut exactly to fit the block? I ended up getting them tapped down more but how would they stick up to far if they are precision cut?
Postby alan » Sun Feb 18, 2018 3:44 pm
You could mike the tops vs the surface so you know how thick that hair is (which I do before pulling the old sleeves), and if it's within a thou I'd not worry. (The likely cause is use-related engine distortion, not irregs in sleeve mfr. )
