YM135D broken front frame and driveshaft
Fine135D
Postby Fine135D » Mon Feb 05, 2018 2:53 pm
So I was moving some dirt on my property when bang the tractor popped out of low gear. I think nothing of it and pop it back into low and let the clutch out. Bang, clunk, clunk, clunk and I am not moving. I get off to inspect for damage and the front driveshaft has snapped. I remove the driveshaft to continue moving dirt until all daylight is gone. The next morning I do a more detailed inspection and find the front frame has completely cracked front to back. I got it removed from the tractor today and found someone else tried to repair it before. The diff pivot points are all egg shaped and there are cracks in the welds going to the side plates that bolt onto the engine. I also observed the diff support plate is actually warped. Any ideas where I might be able to find a used replacement? If I have to rebuild this one I might as well start from scratch as it is so badly messed up. I will try and resize the images on my laptop and add them for reference.
Users browsing this forum: Baidu [Spider], Desert Dave and 8 guests
