I know it's not Yanmar but my FEL...
Jtmachinedesign
Postby Jtmachinedesign » Sun Feb 04, 2018 9:03 am
It's a koyker 110. the bucket *slowly* lowers to dump, even when it's empty
has a Dinoil control valve - im thinking it's got a leaking spool.
Any input? valve p/n 673010
Re: I know it's not Yanmar but my FEL...
Postby winston » Sun Feb 04, 2018 12:58 pm
Could be a cylinder leaking. Swap hoses from lift to curl and see what happens. This will identify whether cylinder or valve.
Jtmachinedesign
Postby Jtmachinedesign » Mon Feb 05, 2018 8:23 am
winston wrote:Could be a cylinder leaking. Swap hoses from lift to curl and see what happens. This will identify whether cylinder or valve.
There's two cylinders on both lift and curl.. if it was a leaking cylinder it would have to be both of them to drift on the curl - that's unlikely.
i'm just going to get a new set of valves and replace the dinoils - my time is worth more to me than putzin around swapping hoses just as a guess. As a bonus, I can get a set with float.
Postby alan » Mon Feb 05, 2018 3:45 pm
You may be right, but I've had to have my lift cylinders rebuilt once -- and the curl ones twice -- over their 5,000 hours. My controller is still the original one, and the bucket stays up (for an hour anyway).
Postby winston » Mon Feb 05, 2018 4:08 pm
No, it would not have to be both of them to leak on the curl. Same pressure line and return on both cylinders. Either one leaks it will go down.
Desert Dave
Postby Desert Dave » Tue Feb 06, 2018 3:36 am
MMMM, spending 20 minutes to swap hoses to isolate a possible small ticket fix against bigger bucks spent that may not be the problem doesn't make any sense to me. It's not a guess as you say, it's working the problem. I certainly wouldn't want my car mechanic just swapping parts out instead of testing to identify the faulty part, just saying.
Postby alan » Tue Feb 06, 2018 5:26 am
If there's quick-connects, it'll take closer to two minutes.
Air-blow any debris before undoing, and mark what hoses currently mate with what hoses before the disconnect/reconnect.
Postby alan » Thu Feb 22, 2018 3:40 pm
They're all "not Yanmar" -- no such thing as a Yanmar loader (despite whatever sticker may be on it) -- at least for the older tractors.
Desert Dave
Postby Desert Dave » Fri Feb 23, 2018 12:49 am
Jtmachinedesign wrote: There's two cylinders on both lift and curl.. if it was a leaking cylinder it would have to be both of them to drift on the curl - that's unlikely.
It's been a while, any new info on your fix to the problem?
Jtmachinedesign
Postby Jtmachinedesign » Sat Feb 24, 2018 9:28 am
Desert Dave wrote:It's been a while, any new info on your fix to the problem?
ya, been working on the plane..
swapped the hoses.. curl still sags.. guess I need to freshen up the cylinders.. doesn't look too hard.
I'll be painting the tractor's sheet metal today.. lime green :) my son has been recreating the decals with my vinyl cutter.
Jtmachinedesign
Postby Jtmachinedesign » Sun Apr 15, 2018 9:04 am
Last post on this topic...
got new piston and gland assemblies from Koyker - that took a few calls. Those guys seem to be too busy to answer their phones :)
super easy to replace.. seriously. Start to finish was barely an hour.
Totally fixed the problem.. only thing I have left to do is replace the wiring and this tractor will be back to work.
