Reminder if Your Tractor will be Sitting
Postby alan » Tue Jan 30, 2018 10:16 am
In some locations snow removal's over and mowing hasn't started, so the tractor sits. If it will be unused for a week, you can use the metal wire clip on the clutch pedal shaft to lock it down. If no clip, find another way because it could prevent a stuck clutch. (Don't know if this is common to all tractors or peculiar to Yanmars.)
Re: Reminder if Your Tractor will be Sitting
Postby winston » Tue Jan 30, 2018 12:34 pm
It is not uncommon for most any manuacturer per my little bit of research.
Postby Norm » Tue Jan 30, 2018 5:04 pm
It happened to my '63 stick shift Ford following a hurricane. Pushed up against a tree, in gear, clutch in, hit the starter a couple of times, broke free.
Users browsing this forum: No registered users and 6 guests
