Steering part for YM2210D
lnwilcoxson
Postby lnwilcoxson » Mon Jan 22, 2018 7:55 am
Hello. New gut here that recently acquired a YM2210D. The steering components are fairly worn and I'd like to replace tie rod, rod ends etc.. any ideas where I can find them .
Re: Steering part for YM2210D
Postby winston » Mon Jan 22, 2018 10:02 am
lnwilcoxson
Postby lnwilcoxson » Mon Jan 22, 2018 10:30 am
Thank you, When I looked at the website section for my tractor the only steering parts listed were for the steering gear itself. If I might ask where did you find that on the site ?
Postby Aaron » Mon Jan 22, 2018 10:51 am
Please keep in mind that we stock THOUSANDS of parts that are not listed (or easily found) on the website. Just click contact us and we can send you a link to whatever you are looking for.
lnwilcoxson
Postby lnwilcoxson » Mon Jan 22, 2018 11:16 am
Thank you Aaron
Postby winston » Tue Jan 23, 2018 5:51 am
lnwilcoxson wrote:Thank you, When I looked at the website section for my tractor the only steering parts listed were for the steering gear itself. If I might ask where did you find that on the site ?
Under front axle.
lnwilcoxson
Postby lnwilcoxson » Wed Jan 24, 2018 9:46 am
I must be doing something wrong. Under the YM2210_Ym2210D section, my model being the YM2210D, the front axle section lists 2WD, 4wd Internal, & 4wd External. I don’t find any tie rods, or ends in photos. What am I doing wrong? Steering section only shows column and gearbox related parts?
O~o\
Postby O~o\ » Wed Jan 24, 2018 10:15 am
lnwilcoxson wrote:I must be doing something wrong. Under the YM2210_Ym2210D section, my model being the YM2210D, the front axle section lists 2WD, 4wd Internal, & 4wd External. I don’t find any tie rods, or ends in photos. What am I doing wrong? Steering section only shows column and gearbox related parts?
As a fellow 2210D owner, I looked all over the parts page and found no tie rods either. I suggest you contact Aaron directly for the link.
lnwilcoxson
Postby lnwilcoxson » Wed Jan 24, 2018 10:34 am
Thank you for responding. At least know I don’t feel like I am clueless.
Postby winston » Wed Jan 24, 2018 11:59 am
My bad. :oops: It is under the axle in 2 wheel drive. Might be the same as the 4 wheel drive. I don't know, checking with Hoye would be the right way to go.
Postby Aaron » Thu Jan 25, 2018 2:21 pm
Sorry about that. I have added a new category '2210D 4wd Tie Rods' with the correct parts
https://www.hoyetractor.com/CTGY/2210.htm
lnwilcoxson
Postby lnwilcoxson » Wed Mar 07, 2018 11:15 am
Thanks Aaron
Users browsing this forum: Google [Bot], winston and 10 guests
