I am owning an old Yanmar Tractor YM1810D (I think from 1981) with the Serial-no. 18B-00951. To get the permession to drive with this tractor on the roads in Germany I need some technical Informations about this tractor:
a: permissible maximum weight
b: axis load front
c: axis load rear
d: Motor power and Motor Rotation Speed
e: Maximum Speed
f: tire size and load index
g: year of manufacturing
h: net weight
Can anybody help me with this Information e.g. with a official data sheet from Yanmar ?
Thank You.
YM1810D Technical data
Re: YM1810D Technical data
1820D maximum speed 13.8km per hour, would think the 1810 would be about the same. Rear tire 8.3-24, front tire 5-14. PTO hp 18, engine hp appx 21 to 22. motor speed 2400rpm. Year of manufacture 1981-?. Appx weight 865kg (1907lbs)., rear axle 453kg, front axle 412kg.
file:///C:/Users/linwinmaberry/Documents/2018-01-18-091245.pdf
file:///C:/Users/linwinmaberry/Documents/2018-01-18-091359.pdf
