Hyd pump
Buddy
Hyd pump
Postby Buddy » Tue Jan 16, 2018 1:50 pm
How do you remove gear off pump to check key and need pump parts diagrams for ym180 thanks
Re: Hyd pump
Postby Aaron » Tue Jan 16, 2018 2:21 pm
#25 is a drive coupler attached to the pump shaft with a nut #26. #25 stays on the pump shaft and will just pull out of the gear #31.
