Front Pulley 187D
doogymon
Front Pulley 187D
Postby doogymon » Fri Jan 05, 2018 11:02 am
Hi
I want to explore running a Hydraulic Pump off the front pulley for an a FEL.
My pulley has two bolt holes instead of 3.
Can I use a drive flange to build out a splined shaft or something?
Hoyes has a part but it is 3 hole.
Cheers & Thanks
Doog
Front_PTO_3 Hole.png (55.7 KiB) Viewed 1028 times
Re: Front Pulley 187D
Postby Aaron » Fri Jan 05, 2018 11:35 am
I would just cut a plate and drill the correct bolt pattern to bolt to your pulley. Then weld a flex coupler to it. The engine turns slow enough that you should be able to get it close enough to centered that the flex coupler will work out any vibration. I did this with a 6000 watt generator that I coupled to a Yanmar 3 cylinder engine. Has worked great for 5 years or so. A local machine shop could make you something more precise if you wanted.
Postby Aaron » Fri Jan 05, 2018 12:45 pm
Yanmar's plan for the 187 front PTO if that helps.
doogymon
Postby doogymon » Fri Jan 05, 2018 2:25 pm
Thanks Aaron
Did Yanmar ever produce that Front PTO Kit for the 187D?
I like your idea with the Flex Coupler.
Cheers
Doog
Postby Aaron » Fri Jan 05, 2018 3:36 pm
Yes, that is it in the picture above.
