ym155d clutch
gjones
ym155d clutch
Postby gjones » Fri Dec 15, 2017 11:47 am
i just installed a new clutch in a ym 155d and when the tractor was married back together the clutch would not disengage. i checked the free play in the peddle and it is set properly, it feels like fingers on the clutch are moving but it still grinds when trying to put it into gear. i did notice the fingers on the new clutch set lower the ones on the old clutch. i know this may make a difference but this is the clutch on hoye's parts page for this tractor. any help would be great.
Re: ym155d clutch
Postby Aaron » Fri Dec 15, 2017 12:47 pm
Are you sure you installed the clutch disc the correct way?
https://www.hoyetractor.com/support/kno ... article=49
There is a design change on the 155 which is not very common (not even listed in the parts manual) but it does take a different pressure plate and longer bearing carrier. That plate is discontinued though so the only option currently, if your plate is bad, is to buy the longer throw out bearing carrier.
gjones
Re: ym155d clutch
Postby gjones » Fri Dec 15, 2017 12:59 pm
yes it is installed correctly and i watch the video just to double check. my throw out carrier is 3 1/8" long, is the one in the parts list longer?
Re: ym155d clutch
Postby Aaron » Fri Dec 15, 2017 1:16 pm
Yes that would be the short version. The long version (3.6") should fix your problem. Link below. What is your tractor serial number? I'm trying to figure out the serial number cutoff to tell future customers which parts they might need.
https://www.hoyetractor.com/PROD/cbs-155L.htm
gjones
Re: ym155d clutch
Postby gjones » Fri Dec 15, 2017 1:20 pm
s# ym155D-55327
Re: ym155d clutch
Postby Aaron » Fri Dec 15, 2017 2:08 pm
Well that ruins my theory. :?
gjones
YM 155d
Postby gjones » Fri Dec 29, 2017 5:03 pm
i installed the longer the longer carrier for the throw out bearing that we ordered from you and now the clutch feels like it disengaged all the time. i have adjusted the linkage and even unhooked it but no change. any ideas?
Re: ym155d clutch
Postby Aaron » Tue Jan 02, 2018 8:49 am
I'm not sure what would cause that. Maybe the shaft fell out of the splined coupler during the reassembly or something? When you push down the pedal does it feel like the it is doing anything?
gjones
Re: ym155d clutch
Postby gjones » Tue Jan 02, 2018 10:03 am
yes it feels the clutch is disengaging but when i put it in gear it wont drive. also when i have it in gear i can go from hi to low and the tractor will jump like the transmission is getting power but thats it.
Re: ym155d clutch
Postby Aaron » Tue Jan 02, 2018 10:13 am
What was going on originally that caused you to replace the clutch the first time? Does it move with the diff-lock depressed or the left or right brake pressed? Does it move in 4wd?
gjones
Re: ym155d clutch
Postby gjones » Tue Jan 02, 2018 10:48 am
original problem was worn out clutch disc and grooved clutch assembly, it will not move with the transmission in any position including diff lock and 4x4.
Re: ym155d clutch
Postby Aaron » Tue Jan 02, 2018 11:16 am
My best guess is that something is going on with the splined coupler (maybe stripped out?) but hard to say from here.
Re: ym155d clutch
Postby Norm » Tue Jan 02, 2018 1:57 pm
Aaron wrote:What was going on originally that caused you to replace the clutch the first time? Did it move with the diff-lock depressed or the left or right brake pressed? Did it move in 4wd?
Why did you suspect clutch problems?
gjones
ym 155D
Postby gjones » Tue Feb 20, 2018 5:55 pm
i installed a new clutch disk, plate and longer bearing carrier in a ym 155D. I know it should have some free play in the peddle but there isnt any, i can remove the linkage from the swing arm and the swing arm is tight with no movement. i cannot get 3/4" of free play in the clutch peddle.
Re: ym 155D
Postby Norm » Tue Feb 20, 2018 8:56 pm
Why did you replace the clutch, and was the original carrier bad? It appears you have tried both the long and short with same result.
Users browsing this forum: No registered users and 7 guests
