Yanmar RS1200 Question
rgtmcc
Postby rgtmcc » Wed Sep 06, 2017 9:58 pm
Can any one supply me with a schematic view of an RS1200 rotory tiller?
Thank you!
Re: Yanmar RS1200 Question
Postby winston » Thu Sep 07, 2017 8:51 am
Don't have that one but yours will be similar to this. https://static.squarespace.com/static/5 ... tiller.pdf
rgtmcc
Postby rgtmcc » Thu Sep 07, 2017 2:15 pm
Thanks for that but the drive to the lower shaft with the tines is different. The problem I have is there is a bolt that locks the inner & outer shafts that the tines are on & it keep snapping with very little work. Is there a special bolt?
Postby winston » Thu Sep 07, 2017 3:09 pm
might try typing in tiller pin in the search box above.
Postby alan » Thu Sep 07, 2017 8:03 pm
You could try a higher-grade bolt. The grade code should be on the head. Don't go too high because if something's going to snap, it had best be that bolt.
