Ym1502D 3 point hitch lever won't stay put
Dahlilama
Postby Dahlilama » Tue Sep 05, 2017 8:13 pm
Ok, I am new to this forum and to small tractors. I can turn a wrench without a problem and used to operate a backhoe as one of my previous jobs. My question is basicslly in the title. I have a yanmar 1502D. I love this sucker so far. It seems to have developed an issue tho. The three point hitch works as it should except for the fact that where ever I put the lever it just moves back up and raises the implement. Shouldn't it stay where I put it? I looked at it for quite a while and can't seem to understand how this darn thing works mechanically. I was going to bolt a piece of angle steel to the lever and make it so it puts pressure along the guide rail but figured I am not fixing it properly. I also looked on google and some tractors have a friction ring....do I have that? Any help would be greatly appreciated. Thabks in advance. Also if you can help remember I don't know the terminology so please put it in Barney terms !!!!!!!!!
Re: Ym1502D 3 point hitch lever won't stay put
Postby winston » Wed Sep 06, 2017 12:05 pm
"If" your 1502 has a double nut shown as #41 in the 220 parts drawing then you should be able to loosen the lock nut, tighten the inner a bit and lock back. Can't see it from here so you will have to decide or post pictures of yours.
220 002.JPG (232.95 KiB) Viewed 390 times
Users browsing this forum: No registered users and 3 guests
