1300d pto connection to Es 1202 tiller
Jpw
Postby Jpw » Fri Aug 18, 2017 3:17 pm
Tractor is a 1300d I believe 1976. I have broken the peace that connects the yoke coming from the tractor pto to the yoke that goes to the tiller. I do not know what it is called, it has places for two u joints that connect to the yokes. without this type of connector the hydraulics will not lift the tiller which is a Rs1202. I will post pics when I figure out how to covert from JPEG file ... Thanks
Re: 1300d pto connection to Es 1202 tiller
Postby alan » Fri Aug 18, 2017 8:07 pm
Don't know that rig at all but speaking generally, maybe you could take the broken bits to a tractor shop to see if they can get a replacement, or a machine shop to see if they can repair it.
Postby winston » Sat Aug 19, 2017 5:33 am
I don't understand what the U joint has to do with lifting the tiller but here is a picture of a cross which is what http://www.agrisupply.com/pto-cross-kit ... 1370/holds the two yokes together.
Users browsing this forum: Bing [Bot] and 5 guests
