Hydraulic pipe on the right side of my 1601D - low or high pressure?
agirlandhertractor
Postby agirlandhertractor » Thu Aug 17, 2017 10:45 am
I noticed that the ~3/4" steel hydraulic pipe that runs from the engine back to the rear end has a rub mark. Thinking about replacing part of this steel pipe with flexible hydraulic hose.
Is this steel pipe a low pressure return line for the 3-point hitch, or is it high pressure?
Re: Hydraulic pipe on the right side of my 1601D - low or high pressure?
Postby Aaron » Thu Aug 17, 2017 11:15 am
The big pipe is suction and the small pipe is pressure. 3/4" size would be the suction.
agirlandhertractor
Postby agirlandhertractor » Thu Aug 17, 2017 11:40 am
Perfect thanks.
Users browsing this forum: No registered users and 2 guests
