ym135 rear axle seal replacement
scottw99
Postby scottw99 » Fri Aug 11, 2017 8:43 am
is the process for the ym135 similar to this guide?
https://www.hoyetractor.com/rear-axle-seal.htm
thanks
Re: ym135 rear axle seal replacement
Postby Aaron » Fri Aug 11, 2017 9:25 am
Yes, very similar. Only instead of having a snap ring on the end of the axle shaft you have a couple of small bolts.
Users browsing this forum: Bing [Bot] and 4 guests
