yanmar 2010 will back up but not go forward
holland
Postby holland » Tue Aug 01, 2017 11:52 am
tractor has been setting will back up fine but wont move forward at all
Re: yanmar 2010 will back up but not go forward
Postby winston » Wed Aug 02, 2017 5:09 am
Haven't heard this one before. I sure don't have a good answer but as usual will spout off. The trouble shooting section of manuals does not cover your symptoms. I would look into the relief valve area. Is you fluid clean and water free?
Postby alan » Wed Aug 02, 2017 6:01 am
Was the problem sudden? Did it follow any particular operation or servicing? Assuming it's PowerShift, check the connection between the horizontal shift lever and the long vertical shaft.
