yanmar 2010 will back up but not go forward
holland
Postby holland » Tue Aug 01, 2017 11:52 am
tractor has been setting will back up fine but wont move forward at all
Re: yanmar 2010 will back up but not go forward
Postby winston » Wed Aug 02, 2017 5:09 am
Haven't heard this one before. I sure don't have a good answer but as usual will spout off. The trouble shooting section of manuals does not cover your symptoms. I would look into the relief valve area. Is you fluid clean and water free?
Postby alan » Wed Aug 02, 2017 6:01 am
Was the problem sudden? Did it follow any particular operation or servicing? Assuming it's PowerShift, check the connection between the horizontal shift lever and the long vertical shaft.
Users browsing this forum: Google [Bot] and 6 guests
