Yanmar f7 specification
kunte
Postby kunte » Fri Sep 30, 2016 6:39 am
I bought a used tractor Yanmar f7. I'm looking for this tractor specifications. The website tractordata this tractor is not on the list. I wrote on yanmar.com but not odgovora.mogoče anyone know where I could get technical specifications and guidelines for this tractor?
Re: Yanmar f7 specification
Postby alan » Fri Sep 30, 2016 6:52 pm
yanmar f7
Just google the above.
kunte
Postby kunte » Sat Oct 01, 2016 7:46 am
I tried google but can not find any specification.
Postby alan » Sun Oct 02, 2016 11:56 am
Sorry, lots of hits but not much info, and what there is seems odd (for instance, the HP of the F7 is 12, 16, 20, or 23, depending on the site). There's some hits on YouTube too.
If we knew what specs you need we might be able to suggest a workaround.
kunte
Postby kunte » Mon Oct 03, 2016 8:08 am
Interested in weight, width and length. Tractor dimensions need to purchase trailers with which it carried.
Postby Norm » Mon Oct 03, 2016 8:24 am
Apparently the F7 was only sold in Eastern Europe by Yanmar.
kunte
Postby kunte » Mon Oct 03, 2016 3:37 pm
However, I would expect to find any data on the tractor.
Postby alan » Mon Oct 03, 2016 3:59 pm
The weight would be about 650kg. If you have it you can take the measurements; otherwise it looks about the size of a 1500, whose dimensions are available. But some day you might want to trailer it with a loader in front and/or an attachment in back.
kunte
Postby kunte » Tue Oct 04, 2016 9:52 am
I got a reply from the Yanmar Europa. The tractor is designed for the Asian market and Yanmar Europe can not give information. I found some information on the Polish side of the listings.
YANMAR F-7
- 3 cylinder liquid-cooled diesel with a power 16,5KM
- 3-speed PTO shaft power
- 4x4
- Split brakes on 4 wheels
- Differential lock
- Manual gearbox
- Six forward gears and two reverse
- Efficient hydraulic pump 35l / min
- Dimensions Length / width / height / wheelbase - 239cm / 109/116/140
- Tire sizes: 5-12 front, rear 8.3-20
Postby winston » Tue Oct 04, 2016 12:54 pm
Any idea what "split brakes on 4 wheels" means? :?:
Postby Aaron » Tue Oct 04, 2016 1:48 pm
I actually just found that I have a parts manual on that model. It is VERY different from the other 'normal' Yanmars. It has a lot of interesting features like the steering system???
kunte
Postby kunte » Tue Oct 04, 2016 2:07 pm
Aaron wrote:I actually just found that I have a parts manual on that model. It is VERY different from the other 'normal' Yanmars. It has a lot of interesting features like the steering system???
Where did you find?
kunte
Postby kunte » Sat Dec 03, 2016 11:26 am
Looking for front right light for my tractor Yanmar f7. On the Russian website I found a light but payment through uniteller, but I do not know. When ordering lights are also an option for which the ordering tractor lamp. You can choose between models F6DT / F7DT / F180DT / F220DT F210DT. Interested in me or are all listed tractors of the same light or the difference elsewhere? Yanmar On the website I read that the tractor F180D F220D can sell well in Europe and thus light orders at Yanmar retailer in Slovenia. The catalog of spare parts for tractor Yanmar f7 the lamp part number 198511-54110. Maybe someone knows whether this is the same light for all of these tractors?
LP Kunte
Postby alan » Sun Dec 04, 2016 4:59 am
"Any idea what "split brakes on 4 wheels" means?"
Other Yanmars have separate pedals for the left and right brakes -- which are on the rear wheels only -- but maybe this model has brakes on the fronts too.
kunte
Postby kunte » Sun Dec 04, 2016 4:57 pm
I do not know exactly how brakes work but when you press the pedal inhibit the first bike. I have not yet had a parable to divide the brake pedal and test how it works if you push just one side of the pedal.
Users browsing this forum: Google [Bot] and 19 guests
