YM 2210B Valve Timing Off???
pxmntws
Re: YM 2210B Valve Timing Off???
Postby pxmntws » Thu Oct 13, 2016 9:37 am
Rings and pistons are new, approximately 10 minutes of run time. Planning to put in new liners.
Postby winston » Thu Oct 13, 2016 2:00 pm
What did your old liner measure at the point where you checked and got the .125" end gap?
pxmntws
Postby pxmntws » Fri Oct 14, 2016 9:02 am
This was measured in large area of the cylinder so around 3.5435".
Postby winston » Fri Oct 14, 2016 9:39 am
The 3.543 is within specs for a new liner. No idea how you could have .125" ring clearance after a 10 minute run but something isn't adding up here.
New liner specs are 3.5433- 3.5447"
Postby Aaron » Fri Oct 14, 2016 12:57 pm
It sounded to me like he filed the new rings to match the gap on the old rings. That gap will leak a lot of compression.
jsrogers67
Postby jsrogers67 » Mon May 25, 2020 9:02 am
I have a 1720D and am experiencing the identical problem. ran fine and parked overnite. now it won't fire. drained and refilled tank with clean fuel; replaced fuel filter; has relatively new injector pump (20 hours ago); primed pump and fuel lines to injectors; removed injectors, and cleaned and checked; replaced cylinder gasket; still get nothing but fuel vapor from exhaust??
I'm dead in the water. about to do a compression test and will post results.
Postby Aaron » Wed May 27, 2020 9:10 am
Did you use any starting fluid when you tried to start it? Lately I have had a bunch of calls where a fuel related problem ends up in an overhaul because of starting fluid.
