yanmar 1500 hydraulics
rwills7ron
Postby rwills7ron » Sat Aug 27, 2016 10:56 am
where is the screen located on trans? and do i need a new gasket when i pull it out?
Re: yanmar 1500 hydraulics
Postby alan » Sat Aug 27, 2016 11:09 am
No gasket, and you'll find posts here (use the Search function) on how to do that.
Postby winston » Sun Aug 28, 2016 3:34 am
http://www.hoyetractor.com/CTGY/YM1500HYD.htm
Probably use old gaskets but only inspection at time can be certain.
Crump
Postby Crump » Tue Aug 30, 2016 2:43 am
did this on my 1610 today ,find your tranny drain plug, (the lowest bolt on the transmission), then on the left hand side of the housing, you will see a triangular plate with three 10mm bolts. Even though you have drained the transmission via the drain, you will get a heap more fluid once you release the screen cover plate, be warned. No gasket, just a specific O- ring, I smeared a very thin layer of gasket goo on the plate just to be sure. Be a pain in the butt if it leaked and you had to drain the transmission again. hope that helps.
Users browsing this forum: No registered users and 26 guests
