Rear axle removal. 1401d
warburtonplayer
Re: Rear axle removal. 1401d
Postby warburtonplayer » Sun Jan 31, 2021 7:54 am
Im not sure on the size I ordered it from hoye I ordered two when I did order so I can measure the new one
Postby winston » Sun Jan 31, 2021 8:08 am
If you ordered the one showing under the 1401 you likely ordered this one which I believe to be a 48mm. https://www.hoyetractor.com/PROD/AS-1300.htm
Probably a part number on the seal.
warburtonplayer
Postby warburtonplayer » Sun Jan 31, 2021 8:30 am
Ordered: 2 Shipping: 2 AS-1300 SEAL REAR AXLE_ $13.63 This is what I ordered it shows the same part number for a 1300
Postby winston » Sun Jan 31, 2021 9:46 am
I believe you need this one but sure don't go on my say so. https://www.hoyetractor.com/PROD/45X70X12TC.htm
warburtonplayer
Postby warburtonplayer » Sun Jan 31, 2021 11:20 am
ok I will call tomorrow
warburtonplayer
Postby warburtonplayer » Sun Jan 31, 2021 11:22 am
How did you find that on the hoye website because I pulled up the one off the 1401. I hope that they sent me the wrong one and its not the axle is bad
Postby winston » Sun Jan 31, 2021 1:54 pm
I input the part numbers from the parts manuals into the Hoye "search" fields. There is actually two parts manuals for the 1300, the 1st edition shows the 48 seal, the newer addition shows the 45 seal. Evidently they made some changes along the way. The 1401 manual I have access to shows the 45 seal.
warburtonplayer
Postby warburtonplayer » Sun Jan 31, 2021 3:07 pm
Ok so it is the 45 seal for the 1401
Postby winston » Sat Feb 06, 2021 5:55 pm
Sure curious about what is going on with your 1401D. :?:
warburtonplayer
Postby warburtonplayer » Sun Feb 07, 2021 6:50 am
Will have a update soon
warburtonplayer
Postby warburtonplayer » Thu Feb 25, 2021 7:07 am
Ok so I put the new seal back in the housing and flipped it upside down and put fluid in it and it did not leak. Put the whole assembly back on while jacked up no leak. Dropped the tractor on the ground and it started to drip again. Could the bearings be bad when weight is put on the axle?
warburtonplayer
Postby warburtonplayer » Thu Feb 25, 2021 7:08 am
Also measured the axle before putting back together and polished it did not seem bent or from.
Postby winston » Thu Feb 25, 2021 7:48 am
"If" you have the correct seal installed, no grooves on sealing surface, axle straight, then a bad bearing could certainly seem likely. It would seem to me if the bearing is that bad then with the wheel off you should be able to feel or see movement up and down or sideways has you move the axle by hand.
warburtonplayer
Postby warburtonplayer » Thu Feb 25, 2021 5:37 pm
I sent in a email to Aaron and he stated to use this seal but might cause wear on the axle. He also spoke about a speedi sleeve anyone ever use one on a axle?
Postby winston » Thu Feb 25, 2021 6:04 pm
Does your axle have any evidence of grooving or wearing? If not, speedi sleeve should not be needed. I have uses a speedi sleeve before, not sure just what on.
Based on your last post I think you need to check your bearings closely.
Users browsing this forum: No registered users and 28 guests
