Rear axle removal. 1401d
Re: Rear axle removal. 1401d
Im not sure on the size I ordered it from hoye I ordered two when I did order so I can measure the new one
If you ordered the one showing under the 1401 you likely ordered this one which I believe to be a 48mm. https://www.hoyetractor.com/PROD/AS-1300.htm
Probably a part number on the seal.
Ordered: 2 Shipping: 2 AS-1300 SEAL REAR AXLE_ $13.63 This is what I ordered it shows the same part number for a 1300
I believe you need this one but sure don't go on my say so. https://www.hoyetractor.com/PROD/45X70X12TC.htm
ok I will call tomorrow
How did you find that on the hoye website because I pulled up the one off the 1401. I hope that they sent me the wrong one and its not the axle is bad
I input the part numbers from the parts manuals into the Hoye "search" fields. There is actually two parts manuals for the 1300, the 1st edition shows the 48 seal, the newer addition shows the 45 seal. Evidently they made some changes along the way. The 1401 manual I have access to shows the 45 seal.
Ok so it is the 45 seal for the 1401
Sure curious about what is going on with your 1401D.
Will have a update soon
Users browsing this forum: No registered users and 15 guests
