Rear axle removal. 1401d
69s1
Postby 69s1 » Mon Feb 15, 2016 11:05 am
How do I remove the r/r axle to replace the leaking axle seal? Its a my 1401d 4x4 w/a PTO. I'm not that familiar with tractors and need some advice. I have removed the tire, hub, etc. and am now looking at the side trans case. Do I have to go in thru the PTO to remove clips?a any info/instruction greatly appreciated. Jerry :?:
Re: Rear axle removal. 1401d
Postby Aaron » Mon Feb 15, 2016 4:15 pm
You have to remove a bolt from the end of the axle (#23) then pull the axle out. To get to the #23 you have to remove your three point lift assembly.
warburtonplayer
Postby warburtonplayer » Mon Jan 04, 2021 1:31 pm
Will the whole lift assembly come out all as one unit?
Postby Aaron » Mon Jan 04, 2021 1:36 pm
It will.
warburtonplayer
Postby warburtonplayer » Mon Jan 04, 2021 1:37 pm
Great thanks ordering more parts!
warburtonplayer
Postby warburtonplayer » Mon Jan 04, 2021 1:39 pm
Once I have it open all I need to do is take the bolt off the end of the axle and pull the bull gear out of the way and the axle will slide out then tap the new seal into the housing then slide the axle back in put the gear in place and bolt down?
Postby Aaron » Mon Jan 04, 2021 2:26 pm
It has been a while since I have done this but I think you are correct.
warburtonplayer
Postby warburtonplayer » Mon Jan 04, 2021 2:47 pm
Also I don't think the rear PTO housing comes out it can stay in.
warburtonplayer
Postby warburtonplayer » Sun Jan 17, 2021 9:52 am
Ok so what is the key to getting to bolt #23 there is no way to get your hadn't down to the bolt. I have everything apart and can't get to the bolt on the axle.
Postby winston » Sun Jan 17, 2021 1:31 pm
warburtonplayer
Postby warburtonplayer » Sun Jan 17, 2021 1:48 pm
Ok so I guess I have to take the whole side cover off in one assembly. I am assuming from the article the brake drum and everything will stay intact. Is the bearing on the end of the axle pressed on or is it just held on by the bearing? Thanks for the help.
warburtonplayer
Postby warburtonplayer » Sun Jan 17, 2021 1:53 pm
Also I am working on the right side with the differential lock will all of that come off intact with the side cover?
Postby winston » Sun Jan 17, 2021 1:59 pm
What would be the inside bearing should just slide out of the transmission housing. When you get the whole axle housing off then the bearing, gear, collar, etc. will be held on the shaft with #23. At least that is what I think I see. :mrgreen:
Postby winston » Sun Jan 17, 2021 2:03 pm
warburtonplayer wrote:Also I am working on the right side with the differential lock will all of that come off intact with the side cover?
No, that will be in and stay in the transmission housing.
warburtonplayer
Postby warburtonplayer » Sun Jan 17, 2021 2:06 pm
Ok so once I pull all the bolts everything should come out as one unit and then I can take the two bolts out slide the axle out pull the seal then repeat. I just don't want to pull the cover and gears and bearing fall out. Thanks for the help.
Users browsing this forum: No registered users and 31 guests
