yanmar ym2000 streering oil capacity
PANAGIOTISKATR
Postby PANAGIOTISKATR » Mon Feb 10, 2014 1:53 pm
hallo, does anyone know the capacity of steering oil for steering box? workshop manual says about 26ml(1)
is this correct? 26 ml is 5 spoons ! is possible workshop manual make a mistake ? please if someone has change his tractor oil please inform me about the capacity.
thanks to all of you
Re: yanmar ym2000 streering oil capacity
Postby winston » Mon Feb 10, 2014 6:21 pm
I have that same I&T manual showing the 26ml. I also have a copy of original Yanmar repair manuals for the ym220/226 and one for the ym276. On steering gear repair pages in both manuals it states to fill the steering gear box with multi-purpose grease. Capacity is .06 gallons (0.24liters) which translates real close to one cup. One cup equals 16 tablespoons.
Confused yet? I know other places say to use 90 weight gear oil and I am not stating which is correct. Nor the quantity. If it were mine I think I would fill it full of 90 weight gear oil if I was satisfied all seals were good. If I doubted my seals I might fill it with multipurpose grease. I would imagine it would run a long time on either. I doubt you can get to much in it.
Postby Norm » Mon Feb 10, 2014 8:39 pm
Yep, fill with 90-140w til it runs out the fill hole. If leaking seals add Lucas Power Steering Sealer. You can't add too much.
Postby alan » Tue Feb 11, 2014 7:31 am
And where the steering shaft comes out of the dash, make sure the black rubber collar prevents water from entering and running down the shaft.
shawn6580
Postby shawn6580 » Mon Sep 11, 2017 11:06 am
Where did you get the manual from?
Postby winston » Tue Sep 12, 2017 4:11 am
