YM 1300D generator/voltage regulator
How can I troubleshoot the generator and voltage regulator. The battery is not charging.
Re: YM 1300D generator/voltage regulator
Unplug the altenator and check the voltage with a AC tester.
You should have AC voltge at the two wires coming out of the dynamo. 90% of the time the charging problems are caused by the regulator though--
http://www.hoyetractor.com/mm5/merchant ... ode=vr-660
or
http://www.hoyetractor.com/mm5/merchant ... ode=vr-160
depending on how many wires your existing regulator has.
or
- Volunteer Poster
My 1301D was doing the same thing. My regulator actually got hot enough to start smoking. New regulator from Hoye Tractor and all was well again.
