Yanmar Tractor How To Videos - new!
yannyboy
Re: Yanmar Tractor How To Videos - new!
Postby yannyboy » Sat Jul 18, 2015 12:13 am
I just bought a reconditioned 3110d from fredricks. It is only a month old with 16 hrs on it. I noticed that my gas cap was low and off center from the hole in the hood. Find out the gas tank imploded on one side whole tank looks like a U shape. Also I believe it is a knuckle seal on passenger side front tire. It is still under warranty but I live over 250 mi away and to me that doesn't sound catastrophic. Is it hard tearing apart the front axle to replace seals? So any video having to do with fuel system or axles would be greatly appreciated!
Thank you!
Postby Aaron » Mon Jul 20, 2015 7:03 am
It will be a while before we can get to making new videos. It has just got very busy here.
Most likely your fuel cap is just not venting and is sucking in the tank as you use fuel.Try loosening it slightly and see if the tank expands back to normal.
Nebrvet
Postby Nebrvet » Fri Jan 26, 2018 2:21 pm
I'd be especially interested in replacement of the linkage for the two speed differential located inside the transmission housing unit!
drt
Postby drt » Mon Mar 26, 2018 7:07 am
Great videos Aaron, thanks very much for taking the time to do them, just so happens that the steering box and brakes are the next 2 jobs on my list, top man :lol:
Yamar1720
Postby Yamar1720 » Sun Aug 19, 2018 6:47 pm
Would be a great help if there was a video on replacing the brake axel shaft on a 1720 since it is the weak link spot on the rear end
Users browsing this forum: No registered users and 13 guests
