Over full hydraulic oil
Erco
Postby Erco » Wed Feb 17, 2021 6:31 pm
Hi
I changed the hydraulic oil on my 186D and did the filters.
After I refilled and ran it a bit I pulled the dip stick and I over filled it a bit .
It about a 1/2 inch above the mark on the stick which I'm guessing is the full mark.
Is it a problem to be a bit over full ?
Do I need to drain some ?
Re: Over full hydraulic oil
Postby Aaron » Thu Feb 18, 2021 1:17 pm
I, personally, would not worry about it but I don't have any actual data or sources to back that up- so continue at your own risk :D . It also would not take much to drain that little bit extra out if you were worried about it.
Erco
Postby Erco » Thu Feb 18, 2021 4:28 pm
Thanks Aaron
I ended up draining out till it was correct.
I missed it by more than I thought, by about 3 litres there abouts.
Better safe than sorry.
Thanks again
RE
