I'm a YM1510d owner and reading here for a while now. This is an awesome community and one of the most helpful boards I ever joined. Typically it goes like I have a problem with... and then it goes to ... your discription is not sufficient... to ... this is a job for professionals ...to ...that's not allowed and the topic is closed...!
You guys from Hoye and all the users are really helpful and I'm happy to joyn this community.
I would like to get your opinion and may be experience with a power steering on a YM 1510d. My tractor has a front end loader and a 3p. Unfortunately last week my steering box broke down. The shaft with the ball nut and the bearings are scrap. Of course, this part was 40 yrs old and I guess the work with the loader (equipped 1 year ago) was to heavy. Now it's quite expensive here in Germany ro rebuild the steering gearbox and I'm thinking about a power steering for this little tractor. But not like the Kit from Hoye with a hydraulic supported steering, I would like to remove the steering box and install an orbital valve instead and a hydraulic cylinder instead of the rod from the steering box to the knuckle.
Is anyone using such a configuration?
Is there enough hydraulic power for power steering, fel, 3p and the power shift with the standard hydraulic pump or must it be replaced.
And where did you connect the cylinder end to?
Would be nice to hear your opinions -may be also from hoye. If you guys have put a plenty of work on it to develop and came to the end it won't work, I don't have to "reinvent the wheel"
Thanks to all
