Yanmar EX3200 - where does this tube go?
gmanobmo
Postby gmanobmo » Thu Feb 11, 2021 1:04 pm
Hi,
I have a 2015Yanmar EX3200 and I just noticed that a rubber tube / hose (right arrow in the picture) that was under my seat is not connected to anything. I looked around and saw that a port or (left arrow), whatever it's called, is open. I assume this hose should connect to this, right? Also, what is this? There is some dirt down in the port which I will try to get out. Just wondering if this has been causing damage.
Thank you.
Griff
IMG_4519 (1).jpg (167.22 KiB) Viewed 163 times
Re: Yanmar EX3200 - where does this tube go?
Postby winston » Thu Feb 11, 2021 6:20 pm
I can't make out much from your pictures but is the hose coming from #24 in this drawing? If so, it is a vent hose.
gmanobmo
Postby gmanobmo » Tue Feb 16, 2021 3:00 pm
Thanks for the diagram and your reply, Winston. 24 looks like it might be the uncovered tube. I assume the rubber tube (right arrow in the picture) should cover that?
Update: I just looked to see if the rubber tube (arrow on the right) connects to something else but it doesn't so I guess I'll just connect it to the metal tube on the left and call it good.
Thank you.
2/18/21 Update: - Just in case others are reading this - I talked with Yanmar and they said the vent tube on the left is supposed to be open like it is shown in the picture. You don't put the rubber hose / tube on it.
The rubber hose / tube on the right should be connected to something on the bottom (he was having a hard time finding what it is but said there is a port from something) and should be open at the top to vent. I'm going to find where is came off and reconnect it.
IMG_4517 (1).jpg (124.15 KiB) Viewed 114 times
Postby winston » Tue Feb 16, 2021 6:22 pm
Having seen your last picture I would agree. The rubber tube is likely there just to get the vent going downward so moisture cannot enter your housing.
gmanobmo
Postby gmanobmo » Wed Feb 17, 2021 8:55 am
Thanks again, Winston.
Postby Aaron » Thu Feb 18, 2021 1:23 pm
The older YM Yanmars did the same thing just without the hose
https://www.hoyetractor.com/PROD/AB-42280.htm
gmanobmo
Postby gmanobmo » Fri Feb 19, 2021 9:33 am
Thanks for your reply, Aaron.
So the Yanmar rep I spoke to on the phone said the rubber tube / hose (red arrow on the right) should connect to something else as a vent tube but I couldn't find anything that was uncovered. Just the metal vent tube (left arrow) which makes me think it should be covering that. Do you know?
Thanks.
Postby Aaron » Fri Feb 19, 2021 10:08 am
Sorry I do not know but I agree with Winston that something has to connect to that tube or it would collect water/dirt/bugs. That hose being right there sure seems like the most likely solution but I don't know for 100%. One of the guys on the 'new Yanmar' Tractorbynet forum that has an EX320 might be able to go look at theirs for you though.
https://www.tractorbynet.com/forums/yanmar-new/
gmanobmo
Postby gmanobmo » Sat Feb 20, 2021 3:54 pm
Good idea. Will try that.
Thanks.
Users browsing this forum: Google [Bot] and 16 guests
