YM2310D Fuel Shutoff / Shutdown Procedure
deplumley
Postby deplumley » Tue Feb 09, 2021 12:20 pm
Hi,
I have a Yanmar YM2310D, starts / runs great but when I go to shut it off I can't just push the throttle level forward to stop the engine. I have to first rev up the engine RPMs and then quickly push the throttle level forward. When it's warm out I can sometimes have to rev up / rev down multiple times before the engine will completely stop.
My understanding is the YM2310D utilizes a fuel shutoff valve off the throttle lever, is there something that needs to be adjusted so I can just push the throttle lever forward to shut the tractor off?
Obviously having to rev up / down to shut something off could be very dangerous in certain situations :D .
Thanks in advance!
Re: YM2310D Fuel Shutoff / Shutdown Procedure
Postby Aaron » Wed Feb 10, 2021 9:17 am
I think you should be able to just adjust the throttle linkage so it moves a little more in the off direction
deplumley
Postby deplumley » Wed Feb 10, 2021 9:38 am
Aaron wrote:I think you should be able to just adjust the throttle linkage so it moves a little more in the off direction
Thanks Aaron! I will give that a shot, I need to replace the friction washer anyways so I'll be in that area soon.
Users browsing this forum: No registered users and 21 guests
