YM 240 injectors
Albert-in-Alberta
YM 240 injectors
Postby Albert-in-Alberta » Tue Jan 26, 2021 6:03 pm
how do you remove the lower injector body from the head
thanks
Re: YM 240 injectors
Postby Aaron » Wed Jan 27, 2021 9:19 am
Are you talking about the lower prechambers (you almost always have to remove the head and press out from the bottom)?
Or the actual injector (use the tool below)?
https://www.hoyetractor.com/PROD/IP-4450.htm
Albert-in-Alberta
Postby Albert-in-Alberta » Wed Jan 27, 2021 4:25 pm
sorry I was referring to the lower chambers in the head... I have the tool to remove the main injector body and have them removed, head is now off the tractor
thanks Albert
Postby Aaron » Thu Jan 28, 2021 8:56 am
You will need to press out the lower chambers. We usually start with a block of wood to try to not damage them but they are typically pretty stuck and end up messing up the tips.
Users browsing this forum: No registered users and 47 guests
