how do you remove the lower injector body from the head
thanks
YM 240 injectors
Re: YM 240 injectors
Are you talking about the lower prechambers (you almost always have to remove the head and press out from the bottom)?
Or the actual injector (use the tool below)?
https://www.hoyetractor.com/PROD/IP-4450.htm
- Volunteer Poster
sorry I was referring to the lower chambers in the head... I have the tool to remove the main injector body and have them removed, head is now off the tractor
thanks Albert
thanks Albert
You will need to press out the lower chambers. We usually start with a block of wood to try to not damage them but they are typically pretty stuck and end up messing up the tips.
Users browsing this forum: winston and 19 guests
