Front axle right side destroyed. Bearings gears axle.
Tony Howard
Postby Tony Howard » Fri Jan 15, 2021 3:44 pm
Does someone sell rebuilt front end parts?
Re: Front axle right side destroyed. Bearings gears axle.
Postby winston » Fri Jan 15, 2021 5:11 pm
How about used parts? Have you checked with Hoye? Yours parts manual with part numbers is on line, have you identified parts with part numbers? At least I think you have a 2020D.
Tony Howard
Postby Tony Howard » Fri Jan 15, 2021 7:46 pm
Yes, I have a 2020D. I didn't know if I had to rebuild this one, or buy one housing and all rebuilt to bolt on.
Postby winston » Sat Jan 16, 2021 5:20 am
Tony Howard wrote:Yes, I have a 2020D. I didn't know if I had to rebuild this one, or buy one housing and all rebuilt to bolt on.
I doubt you will find a rebuilt one, more likely a used one but then you might not know exactly what you were getting. You can browse your 4 wheel drive parts on this sight. https://www.hoyetractor.com/CTGY/2020.htm
Tony Howard
Postby Tony Howard » Mon Jan 25, 2021 4:37 pm
Aaron, you have a used axle?
Do you have any of the other gears for front axle in used parts. I need all of them to rebuild.
Postby Aaron » Tue Jan 26, 2021 11:41 am
We have parted out several axles over the years but I don't have a complete axle assembly. Just contact our parts department and let them know what all pieces you need and they can see what we have.
Users browsing this forum: Google [Bot] and 28 guests
