JD-870 Rear Fuel Filter
Dietpepsi
Postby Dietpepsi » Fri Jan 15, 2021 7:08 am
I own a 1995 John Deere 870 with a three cylinder Yanmar diesel engine. I have been replacing its filters. There is a fuel filter, with an aluminum housing/valve and plastic bowl and replaceable paper filter just below the fuel tank on the right side. The bowl on mine has plenty of cracks in it, and I’m afraid it will collapse if I try to remove it. I can’t find any mention of it online, and no source to replace it. Can you help me find a replacement?
Re: JD-870 Rear Fuel Filter
Postby Aaron » Thu Jan 21, 2021 12:18 pm
Sorry such a late reply but it will be one of the bowls below (depending on the diameter of your filter). If you can get me the OD of the old bowl I can match up.
https://www.hoyetractor.com/PROD/FB-9155.htm
https://www.hoyetractor.com/PROD/FB-1.htm
Users browsing this forum: hrtull and 17 guests
