What batterie 226D
What batterie 226D
Was thinking of trying a AGM batterie. Have no idea what size. Anyone have any ideas. If this is a bad idea then what size regular batterie. I live in west Michigan winters can get cold. Please and thanks
Re: What batterie 226D
The 226 manual calls for a group 24 battery, 270 cold cranking amps, reserve capacity 80. What AGM battery would match that I have no idea.
Thank you that should help me get it close. From what I’m reading the AGM batterie is not necessary or practical. I was just hoping to get a bullet proof batterie that didn’t mind the cold . I’ve been recommended to jus use a tender in the winter. Thanks again
Kuhnsja wrote:Thank you that should help me get it close. From what I’m reading the AGM batterie is not necessary or practical. I was just hoping to get a bullet proof batterie that didn’t mind the cold . I’ve been recommended to jus use a tender in the winter. Thanks again
I am a cheapskate but have had good luck with the Walmart sold batteries. At the same time I don't face the extreme cold here in Northeast Texas.
Users browsing this forum: winston and 39 guests
