2tr20a-a ym2000
Rickc
2tr20a-a ym2000
Postby Rickc » Tue Jan 05, 2021 8:43 am
Hello I've got ym2000 with 2tr20a-a. I've put new sleeves rings had head done. Got running but smokes white smoke. And smells like to much fuel. I've put new injector s in it. Thanks for any help. Rickc
Re: 2tr20a-a ym2000
Postby winston » Tue Jan 05, 2021 9:37 am
No answers, just questions. Have you tried loosening injector line to each cylinder to try and identify which cylinder might be weak? Have you ruled out coolant in cylinders? Did you have the injection pump out for any reason?
Rickc
Re: 2tr20a-a ym2000
Postby Rickc » Tue Jan 05, 2021 10:33 am
Yes sir when i loosen each one has same effect. I've pull injector pump to add shim. I'm not seeing any loss of coolent
Re: 2tr20a-a ym2000
Postby winston » Tue Jan 05, 2021 11:12 am
Rickc wrote:Yes sir when i loosen each one has same effect. I've pull injector pump to add shim. I'm not seeing any loss of coolent
Did you do this after the white smoke or before? Valves adjusted at .006"?
Rickc
Re: 2tr20a-a ym2000
Postby Rickc » Tue Jan 05, 2021 12:48 pm
It smoked before and after but didn't as bad after. I've got another problem. Trying to add shim to fip lost little round shim that goes on top of gov arm will it just go to oil pan. Thanks rickc
Re: 2tr20a-a ym2000
Postby winston » Tue Jan 05, 2021 2:26 pm
That would be my guess. Why are you adding shims?
Rickc
Re: 2tr20a-a ym2000
Postby Rickc » Tue Jan 05, 2021 3:16 pm
I thought if its pumping to much fuel you shim the fuel pump out
Re: 2tr20a-a ym2000
Postby winston » Tue Jan 05, 2021 4:23 pm
Shims are what changes the timing. Each .0039" shim changes timing appx 1 degree. Adding shims will retard your timing.
Rickc
Re: 2tr20a-a ym2000
Postby Rickc » Wed Jan 06, 2021 7:03 am
Thanks for setting me straight wiston. I am learning the hard way. I'm just doing it. Thanks again rickc
Re: 2tr20a-a ym2000
Postby Aaron » Wed Jan 06, 2021 10:15 am
Does it start easily?
Rickc
Re: 2tr20a-a ym2000
Postby Rickc » Wed Jan 06, 2021 1:28 pm
Yes sir put original shims back in runs lots better. It still smokes a little should i try to take one more shim out and try it. Thank you. Rickc
Re: 2tr20a-a ym2000
Postby winston » Wed Jan 06, 2021 2:48 pm
If you have the original amount of shims and same pump then timing should be correct. You can check it if you think your up to it. Instructions on page 48 of this 195 manual. Very close to your 2000. file:///C:/Users/linwinmaberry/Downloads/YANMAR%20YM195%20SERVICE%20MANUAL.pdf
Users browsing this forum: Google [Bot] and 21 guests
