Yanmr 1401 Flywheel
warburtonplayer
Re: Yanmr 1401 Flywheel
Postby warburtonplayer » Sat Jan 09, 2021 6:24 am
The 169 is very similar in size but it has the two piece clutch linkage. The 1401 has a one piece.
warburtonplayer
Postby warburtonplayer » Sat Jan 09, 2021 11:55 am
I was just working on the tractor and noticed that the clutch pedal spring does not have much spring to it. I can push down on the pedal and the spring really does not have much tension until the clutch is half way down. Could this also be a factor?
Postby winston » Sat Jan 09, 2021 1:25 pm
The spring should pull it back until it hits the stop. If it does that then no problem. If not, then a problem.
warburtonplayer
Postby warburtonplayer » Sat Jan 09, 2021 1:50 pm
Yeah the spring does not pull it all the way back once it is depressed then it stays about 2 1/2 from the stop. I guess I need to order a spring also
Users browsing this forum: No registered users and 39 guests
