Yanmar 1401 starter
warburtonplayer
Yanmar 1401 starter
Postby warburtonplayer » Fri Dec 18, 2020 11:13 am
My 1401 I am working on the starter kept grinding really bad so I got a new one put it on and it is still grinding really bad. I have not pulled the tractor apart yet to see about the fly wheel but will need to pull the tractor apart because the clutch is at the max fo adjustment and will need a new one. Any thoughts on the starter why it would still be grinding?
Re: Yanmar 1401 starter
Postby winston » Fri Dec 18, 2020 2:59 pm
If the starter is the correct one and good then it would seem likely the flywhee ring gear. You might conseder looking it over some with the starter out.
https://www.hoyetractor.com/PROD/124060-21600.htm
Postby Aaron » Fri Dec 18, 2020 6:39 pm
I replied to your ticket about this also but sometimes low voltage will do that too. Bad connection, low/bad battery...
warburtonplayer
Postby warburtonplayer » Fri Dec 18, 2020 7:32 pm
I have a brand new optima battery in it but I will check to see if the wiring is jacked up the previous owner wired some sort of relay onto the starter not sure why?
warburtonplayer
Postby warburtonplayer » Wed Dec 23, 2020 6:09 pm
Ring gear is completely trashed on the starter side ordered a new one today.
Postby winston » Wed Dec 23, 2020 6:52 pm
You probably know how to remove and install ring gear but if here is instructions from 276 manual. 226 manual reads about the same.
warburtonplayer
Postby warburtonplayer » Thu Dec 24, 2020 6:00 am
Yeah I am guessing since it has been on so long it will need a lot of heat to break it off the fly wheel. Will update when the part comes in
Users browsing this forum: No registered users and 38 guests
