Yanmar 1401 End boot
warburtonplayer
Postby warburtonplayer » Wed Dec 16, 2020 11:48 am
I need to find a tie rod end boot right where the pitman arm connects to the steering arm on a Yanmar 1401 tractor. Thanks
Re: Yanmar 1401 End boot
Postby winston » Wed Dec 16, 2020 1:13 pm
Not sure this is the one so contact Hoye parts to make sure. https://www.hoyetractor.com/PROD/DC-4730.htm
warburtonplayer
Postby warburtonplayer » Thu Dec 17, 2020 1:48 pm
Thanks also can I use RTV gasket material for the hydraulic screen mount rather than the paper gasket?
Postby Aaron » Thu Dec 17, 2020 4:24 pm
It might be better to cut a paper gasket by hand (you can get the material from an auto parts store) and put a thin film of RTV on it. It is a pretty simple pattern. RTV works well on a lot of things but I, personally, have not had good results on things that were below the oil line or that were under any pressure. Your mileage may vary though.
Users browsing this forum: No registered users and 21 guests
