Yanmar 1401 End boot
- Volunteer Poster
I need to find a tie rod end boot right where the pitman arm connects to the steering arm on a Yanmar 1401 tractor. Thanks
Re: Yanmar 1401 End boot
Not sure this is the one so contact Hoye parts to make sure. https://www.hoyetractor.com/PROD/DC-4730.htm
- Volunteer Poster
Thanks also can I use RTV gasket material for the hydraulic screen mount rather than the paper gasket?
It might be better to cut a paper gasket by hand (you can get the material from an auto parts store) and put a thin film of RTV on it. It is a pretty simple pattern. RTV works well on a lot of things but I, personally, have not had good results on things that were below the oil line or that were under any pressure. Your mileage may vary though.
Users browsing this forum: AltonaEric and 25 guests
