Hello, I purchased a Yanmar 1500D, when I got home I discovered the pto housing was busted. I removed the broken cover and found the gear had missing teeth and the rear bearing outer housing and balls were gone. I ordered a new cover, gear and bearings. My question is how is the bearing with the snap ring placed on the shaft, with the ring toward the gear or toward transmission end of the shaft?
This is a great place for information on maintaing and operating our tractors. I purchased the operators manual, it wasn’t quite what I expected but it’s better than nothing I suppose.
PTO upper bearing w snap ring placement
Re: PTO upper bearing w snap ring placement
I don't have one here to double check but it will only go together one way and I'm +90% sure the bearings gets positioned so it sinks into the rear axle casting as far as possible (snap ring to the rear of the tractor). If you put it the other way the cover will not go all the way on. Someone uploaded some pictures here once but I'm not able to find them now.
Thank you for the reply. I did get the shaft assembled, but had to take it to a machine shop to have it pressed in the PTO cover. I failed to mention that the hole in the transmission housing has been gauged about a 1/4 “ and the hole itself is a little rough. I plan to file the opening and I was going to put some JB weld in the gouge, but it’s too cold for it to set properly and I don’t have a shop.
I plan to change the hydraulic fluid and clean the screen today, I have a magnet and will “ go fishing “ for metal in the transmission housing. The lower gear has a bevel on one side and is flat on the other, do you know which side faces the front of the tractor?
What part of the gear is the bevel on? Can't see why gear teeth would have a bevel unless from wear.
The lower gear has a washer that is flat on one side and convex on the other. Thank you for the reply.
Maybe this thread will shed some light on it for you. viewtopic.php?t=4985
Users browsing this forum: No registered users and 33 guests
