Yanmar 186D power steering conversion
donsberg
Postby donsberg » Thu Dec 10, 2020 4:47 pm
Hi,
I have Yanmar 186D legal in the US Red Tractor.
Do you have a way to install power steering on it?
The charging system light stays on when running but system is charging 14.2 volts when checking with a meter and the battery doesn’t run down. What could be wrong?
Don
Re: Yanmar 186D power steering conversion
Postby Aaron » Fri Dec 11, 2020 10:15 am
The only option I have right now is below but I think the overall length is too long for the 186D
https://www.hoyetractor.com/PROD/psc-178.htm
I have seen other customers adapt a small orbital steering valve and a regular hydraulic cylinder that seemed to work good and replaces the stock steering box.
The charging light is most likely caused by a bad regulator (it is what controls that light) or a bad connection somewhere.
Users browsing this forum: No registered users and 43 guests
