169D clutch replacement info
scrappy1
Postby scrappy1 » Mon Nov 16, 2020 1:31 pm
Hi.
After watching several Youtube videos about Yanmar clutch replacement, it seems like the steering wheel and dash cowl must be removed to split the machines. But, as I inspect and study the way my 169D is assembled, it sure looks like this tractor splits in front of the dash cowl. Does anyone know if that's accurate?
Thanks.
Re: 169D clutch replacement info
Postby Aaron » Tue Nov 17, 2020 11:21 am
You could probably do it either way. If you leave the dash on the rear half of the split then you have a lot more wires and stuff to unhook (since almost all of the wiring /controls/cables from the dash goes forward to engine & battery). If you leave it on the front half then you basically just have to unhook the fender lights.
scrappy1
Postby scrappy1 » Wed Nov 18, 2020 2:32 pm
Thanks. Since it appears the steering wheel would be destroyed trying to remove it, I'm going with leaving the dash on the back half. I got the FEL sub frame off today (not trying to rush this). I have the factory manual for the YFL580 loader, and it appears that the loader might also fit other Yanmars. Is there a way to check that?
Postby Aaron » Fri Nov 20, 2020 11:10 am
It usually is not that bad. The steering wheel in our video was extra obnoxious for some reason. Usually they come off much easier than that.
Users browsing this forum: Hugh17 and 18 guests
