tractor will not move
rcw
Postby rcw » Thu Oct 29, 2020 5:07 am
im a new owner of a 335d , tractor stopped moving the other day. no forward or reverse but pto and 3 point still work. any ideas where to start looking would be appreciated. seems to be full of fluid.tried adjusting clutch, no change.
Re: tractor will not move
Postby Aaron » Thu Oct 29, 2020 9:40 am
Is that an FX335? Have you cleaned your internal screen lately?
rcw
Postby rcw » Fri Oct 30, 2020 4:24 am
its a ym336d ,last owner says its been almost 2 years since screen was cleaned but ill pull it and look. thanks
Postby winston » Fri Oct 30, 2020 5:43 am
"Assuming" the pto works with power. If that is the case your clutch could be eliminated.
No doubt as Aaron has suggested your spin on filter and suction screen would be the first place to check. If that checks out I believe your power shift relief valves would be next. Do you have column or floor shift?
rcw
Postby rcw » Fri Nov 13, 2020 7:53 am
cleaned screen ,tractor moves now.thanks for help
Users browsing this forum: Hugh17 and 14 guests
