Gannon Box Scraper attachment
Humboldtdan
Postby Humboldtdan » Thu Oct 15, 2020 2:40 pm
I have a 1500D and I am trying to attach my gannon box scaper but three point attachment is too wide for the scraper. What is the easiest way to attach? Should I purchase different arms or? Thanks
Re: Gannon Box Scraper attachment
Postby Aaron » Fri Oct 16, 2020 9:12 am
You can usually either use offset lift arms like below
https://www.hoyetractor.com/PROD/la-245.htm
or, on some implements, you can turn the lift pins inward and that usually also work. Some implements have some structure pieces in the way that prevents that though.
Humboldtdan
Postby Humboldtdan » Fri Oct 16, 2020 10:55 am
Thanks!
Users browsing this forum: No registered users and 48 guests
